Mesh w/ Vertex Colors in AutoCAD?
- Full Name: Todd Davis
- Company Details: 21st Century Forensic Animations
- Company Position Title: Vice President of Animation
Most softwares I've worked with that convert a point cloud to a mesh utilize vertex colors to shade the resultant mesh appropriately. This displays great inside 3dsMax but I'm wondering if anyone has found a way to get the mesh to display with vertex colors when imported into AutoCAD?
Currently I can import the mesh but the vertex colors do not show up. It only displays with a default material of one color.
If anyone could shed some light on this I would greatly appreciate it.
- gilles_3DR
- Full Name: Gilles Monnier
- Company Details: Hexagon
- Country: France
- Been thanked: 28 times
Re: Mesh w/ Vertex Colors in AutoCAD?
Hi Todd,
When rendering a mesh, you need to differentiate between 1/ textured mesh and 2/ mesh with color on the vertices.
Some SW can do only one or both. Same for file formats...
Which format are you using to import in autocad?
- mmarsault
- Full Name: Matthieu Marsault
- Company Details: Murphy Surveys Ltd.
- Company Position Title: Laser Scanning Manager
Gilles,
could we export a Mesh with the colours from the vertices in reshaper ?
- gilles_3DR
- Country: France
Yes, in 3dreshaper, you can have either colored/inspected or textured meshes.
You will get a colored mesh by using the dedicated function which uses the color of the points of a point cloud to apply to the vertices.
In the case of a colored/inspected mesh, you can export the color to a format that supports it (for example .ply).
As for textured mesh, the most common format to export texture would be .obj
- mmarsault
I have a mesh which is using "2/ mesh with color on the vertices". Displays fine in 3dsMax but when I export it as a .dwg and open in AutoCAD the model shows up but not the vertex colors. It's just all shaded one color. I'm going to assume AutoCAD does not handle vertex colors?
- gilles_3DR
- Country: France
Could also be that 3dsmax, when exporting to DWG doesn't include the color...
Thanks for the feedback. Do you know of a file format that does support "2/ mesh with color on the vertices"?
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
ply is usually a good option but unfortunately autocad does not support it..
- Country: Italy
You can try with meshmixer. You can save an obj with per vertex color, besides the textured version.
At this point you *might* have a 3dstudio file with per vertex colors to import in autocad?
edit:
it looks it's not working as expected.
there is a trasfert mesh to vertex in meshlab, that could be a good candidate....
edit:
