undulation computation?
- Full Name: Andrzej Namyslak
- Company Details: Jersey City NJ
- Company Position Title: Not applicable
Can you guys recommend software other than amberg tms that would allow to represent undulations on raster image (color coded)? I'm dealing with arched geometries (caverns). Any help will be greatly appreciated.
Thanks.
Thanks.
- LeicaUK_RC
- Full Name: Phil Marsh
- Skype Name: Phil.H.Marsh
- Been thanked: 52 times
Re: undulation computation?
Have you tried 3D Reshaper or GEOMagic?
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
Cloudcompare.... its free, and a brilliant product.
http://www.danielgm.net/cc/
http://www.laserscanningforum.com/forum ... 144&t=7287
Mike.
Mike.
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
I would agree on Cloud Compare, works really well and yes, it's free!
- Full Name: Richard Stuckey
- Company Details: Richard Stuckey
I would highly recommend cloudcompare as well as GOM Inspect. Both are free. Cloudcompare is proabably easier to get up and running, but I have been using GOM Inspect for only a week and its meshing and analysis tools continue to astound me.
- Matt Young
- Honorary Member
I'm going to give GOM Inspect a go.
- Matt Young
- Honorary Member
I did download GOM Inspect and give it a quick go - only issue is finding the right format to get scan data into it. It doesn't really seem geared up for terrestrial data and seems to have no way of getting ptx/pts files in?
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
I think no way to import ptx, but pts should work in GOM.
When importing select ascii file
You can the create a template, and in case your file ghas normals you can get them in too..
- Matt Young
- Honorary Member
Yep, tried that, but only have limited options for the ASCII layout - none of them seem to work. PTS is x,y,z,intensity and there is no template option for intensity as far as I can tell.
- Country: Italy
Gom ignores intensity and RGB (after all their scanner are not getting intensity nor color).
Simply select ingnore for the last field. If there are not suitable templates you can click edit on one, copy it (the original is locked) and adapt to suit.
