AutoCAD not handling RCP files (freezing and jumping around)
Discuss Autodesk ReCap Studio software here.
jackbidston
4
Full Name: Jack Bidston
Company Details: Bidston Draughting
Has thanked: 4 times
Post by jackbidston »
I do a lot of measured building surveys for residentail and commercial properties,
I use a Faro X330 to capture, Faro Scene to Process and Register And AutoCAD 2020 to Draught Plans, Sections & Elevations.
The problem I have is AutoCAD just not handling the poiuntclouds, it will work fine for a few days then all of a sudden it the pointcloud will start jumping around and crashing. I take all the precautions that I know about for example turning off scan locations I dont need using the point cloud manager, reducing the level of detail where I can afford to without affecting accuracy and cropping on the area I am working on at the time.
This is extremely problematic to me and costing a lot of time, Is anyone alse aware of anything I can do to improve the performance in AutoCAD?
Jack
markscan
I have made 80-90 posts
6
Full Name: Marco Dileo
Company Details: ARcontrol
Has thanked: 32 times
Been thanked: 12 times
Re: AutoCAD not handling RCP files (freezing and jumping around)
Post by markscan »
All you can do is to complain with them (Autodesk) on their forum and hope one day they will improve and update their damn ReCap software.
Meanwhile switch to another platform\format: I use Leica Cloudworx for AutoCAD.
jamesworrell
9
Full Name: James Worrell
Has thanked: 14 times
Been thanked: 87 times
Post by jamesworrell »
Large coordinates or local?
jackbidston
4
I am working Locally on this project (in and around 0,0) but seem to thave the problem no matter where it sits globabaly
jamesworrell
9
Large coordinates in ACAD with point cloud absolutely has issues - osnap etc - that is well documented.
Local - hard to say - we typically use cloudworx, so haven't really noticed it. Imagine the usual applies - graphics drivers would be where I'd start. Nvidia? Try the studio drivers - they are more stable.
mariusP
11
Full Name: Marius Putrimas
Company Details: Terra Modus
Company Position Title: Undet product manager
Country: Lithuania
Has thanked: 30 times
Been thanked: 45 times
Post by mariusP »
jackbidston wrote: Wed Feb 19, 2020 10:10 am
You should try Undet for AutoCAD. No problems with large point cloud files or very large coordinates systems. If you are using FARO webshare service you should check UNDET browser (https://youtu.be/yDOTDol_jcA), which helps you a lot.
https://youtu.be/BxWeAv5rr5Q - here is floor plan workflow video
https://youtu.be/STKcTm6nwR4 - simple 3D modeling workflow
P.S. If you need a live demo PM me.
Undet Point Cloud Software provides software solutions for AutoCAD, ARES Commander, Revit, and SketchUp point cloud users to save time, increase efficiency, and reduce errors in creating 3D models and 2D drawings.
:arrow: www.undet.com
jackbidston
4
I have this morning downloaded a trial as someone else had mentioned it in another forum, But I can see absolutely no benefit unfortunately.
mariusP
11
Country: Lithuania
Post by mariusP »
jackbidston wrote: Wed Feb 19, 2020 3:23 pm I have this morning downloaded a trial as someone else had mentioned it in another forum, But I can see absolutely no benefit unfortunately.
If RECAP functions are more than enough in your daily point clouds to 2D drawings workflow, we have developed Undet with Ares Commander solution to significantly lower annual costs on CAD systems. 1-year license is only 750e and you will have all the necessary tools to prepare elevations, sections, and floorplans. In both plugins is an integrated UNDET database. With UNDET Indexer you can create UNDET point clouds project much faster than using Recap, and you will have full control of each file. https://www.laserscanningforum.com/foru ... 71&t=15814
P.S.I found your download form, my colleague Andrius will contact you for a live demo, to explain the UNDET software concept (of course, if you will have free time).
Damien3D
6
Full Name: Damien Sautarel
Company Details: ats
Company Position Title: Industrial Digital Solutions
Has thanked: 3 times
Post by Damien3D »
How big is the point cloud you're working on?
We use Cloudworx with Jetstream for Autocad, Microstation and SP3D.
Might be a bit pricey depending on how much you use point clouds but so smooth with very large projects.
stutosney
5
Full Name: Stuart Tosney
Company Details: ---
Company Position Title: Associate Director - Survey
Country: London
Has thanked: 25 times
Been thanked: 58 times
Post by stutosney »
+1 for cloudworx. Was always the go to for 2D floor plans, sections and elevations
