Want to reduce the size of the support files
benzilliox
Full Name: Benjamin Zilliox
Company Details: KLH Engineers
Company Position Title: CxA
Skype Name: Ben Zilliox
Post by benzilliox » Tue Mar 12, 2019 12:58 pm
I am having trouble sending the files as the support file folder is like 17 gigs and i have to send the support files with the .rcp file...Any suggestions here?
Thanks in advance,
B
tengui
Full Name: NEDELEC Tanguy
Company Details: Prigent et Associes
Re: Want to reduce the size of the support files
Post by tengui » Tue Mar 12, 2019 1:22 pm
You can safely delete the "Temporary Cache Files" folder in the support folder. Only drawback is that Recap will need to rebuild the Realview image of a scan the first time you access one.
You can also compress your project with 7-Zip or equivalent (choose a strong compression option).
The resulting file will still be several GB though, so your only alternative might be to physically send a disk or SD card.
LPaulCook
Full Name: L Paul Cook
Post by LPaulCook » Tue Mar 12, 2019 1:52 pm
When I need to send a large compressed file I use SendThisFile.com and FireFox web browser. Other browsers have a 4GB maximum limit.
L. Paul Cook, PLS
www.LPC3D.com
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Post by gsisman » Tue Mar 12, 2019 4:50 pm
Thanks in advance,
B
Ben
Remember that the RCP file is just a pointer file to the other files. That being said there is a forum items from some Recap engineers a while back (before they all got cut!) about how to reduce your RCS file size (the actual scan data) and KEEP all your photo bubbles (individual setups for viewing the scan station photos, I've tried it before and it works. Just set your spacing size for points to what is required by the client, then zip all into a compressed file. You can get 2TB of storage from Google or Dropbox for about $5. Use that or DropBox to create a folder you can share where they can download it (if they have a fast connection) - or Invest in a lot of 16-32GB or higher Memory Keys to just ship the data to them:
https://knowledge.autodesk.com/support/ ... views.html
