From: https://forums.autodesk.com/t5/recap-fo ... -p/7414800
Please see note at the bottom about updating firmware as well.
-Ryan
Autodesk ReCap Pro for Mobile Update version 1.1.10
This release note contains the latest information regarding the installation and use of this update. It is strongly recommended that you read this entire document before you apply this update to your product. For reference, you should save this document to your hard drive or print a copy.
Affected product: Autodesk ReCap Pro for mobile (version: 1.0)
iTunes link: https://itunes.apple.com/us/app/autodes ... 33461?mt=8
Release notes:
- Map view now shows the entire, current scan group, rather than individual scans.
- An overhead preview of registration alignment is now available for both automatic and manual registration.
- Manual registration can now be done from map view.
- Scans on the BLK360 are now grouped by capture date for easier management.
- Support for iOS 11.
- In-app notification during desktop transfer.
- Fixed a crash that could occur when taking multiple high density scans.
- Enhanced error handling and reporting.
- Miscellaneous stability improvements.
Recommended BLK360 firmware: 1.0.3
Firmware install instructions:
https://knowledge.autodesk.com/support/ ... anner.html
Firmware Location:
https://lasers.leica-geosystems.com/sit ... _1.0.3.zip
ReCap Pro for Mobile - Version 1.1.10 Released
- Full Name: Ryan Frenz
- Company Details: Autodesk
- Company Position Title: Engineering Manager - ReCap
Re: ReCap Pro for Mobile - Version 1.1.10 Released
The links were broken in my original post due to a copy/paste error (thanks Thad for catching). The proper links are there now, and adding this note to bump.
-Ryan
-Ryan
- topogeo
- Full Name: piercarlo roasio
- Company Details: studio roasio
- Company Position Title: titolare
- Country: italy
- Has thanked: 24 times
- Been thanked: 25 times
I recognize that with this update, RecapMobile is much more stable.
the connection and synchronization with the BLK360 go much better.
Piercarlo
Piercarlo
- Full Name: Justin Hays
- Company Details: ADF Engineering
- Company Position Title: Designer
I am having issues with it staying open when reviewing a project on the iPad...is there anyone else having this issue?
