e57 data missing chunks in RECAP
berdindc
Full Name: Dan
Company Details: Berding
Post by berdindc » Thu Aug 10, 2017 9:45 pm
My e57 out of Cyclone is clearly missing chunks of data, see screenshot.
Anyone know of this issue? I know I'm due for an upgrade, so i'll try and run that tonight. But is this a known problem? Repeating the export process results in different chunks missing, it's not consistent. I don't know if the issue is on the Cyclone OUT end or the ReCap IN end....
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Re: e57 data missing chunks in RECAP
Post by Phil Marsh » Thu Aug 10, 2017 10:06 pm
Did you do two scans from the same setup? i.e. sub selection or quick scan?
angkeankeong3
Full Name: Ang
Company Details: IDE
Company Position Title: Surveyor Section Head
Country: Malaysia
Post by angkeankeong3 » Fri Aug 11, 2017 1:51 am
Yuelin
Full Name: Yuelin
Post by Yuelin » Fri Aug 11, 2017 3:44 am
You can try to import the E57 file back into Cyclone to see if you get the same result as the one before export.
pburrows145
Full Name: Paul Burrows
Skype Name: pburrows145
Post by pburrows145 » Fri Aug 11, 2017 1:37 pm
My thoughts exactly. Try and re-import into Cyclone (once exported) and see if the data is missing. This will help identify where the issue lies.
jamesworrell
I have made 100> posts
Full Name: James Worrell
Post by jamesworrell » Fri Aug 11, 2017 1:42 pm
Just for fun try a PTG.
Other thing to look for .. how is your empty space on your HDD looking? Not a full drive?
Normally I'd +1 for the multiple scans per station without unifying the station - but if not a repeatable result I'd be tempted to look at space on HDD ..
berdindc
Full Name: Dan
Post by berdindc » Fri Aug 11, 2017 7:18 pm
I took the same e57 back into Cyclone and it looks good, no data missing. See image (Cyclone screenshot). Issue would seem is on ReCap IMPORT end of the deal.
I was able to import the PTX, which looks okay, but the units are in "feters" (meters x 3.28083) This won't do as I'm trying to merge with the interior FARO scans.
All Leica scans (Cyclone out) were just one 360 scan per set-up, plus the target scans. But no subselection scans.
berdindc
Full Name: Dan
Post by berdindc » Fri Aug 11, 2017 7:33 pm
Since I only have 11 exterior scans, I did them all as single e57's. Still, no good. Screenshot from Recap "real-view" showing missing data...
EDIT: plenty of room on SSD drive and the interior HDD
Ryan
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan » Sat Aug 12, 2017 2:51 am
That's strange. Looks like you're on an older version so maybe retry with all updates. Otherwise if you can share one of the problem files we can take a look.
-Ryan
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 » Sat Aug 12, 2017 10:50 am
Could it be a big coordinates issue?
