Deleted Points in Recap Visible in Revit
Discuss all Autodesk ReCap Studio related issues here.
robertbon
Full Name: Robert Bonnington
Company Details: Bonnington Surveys Ltd
Post by robertbon » Mon Apr 16, 2018 2:00 pm
I've created an rcp in Recap and then used the delete tool to clean it up a bit. When I then import it into Revit the "deleted" points are still visible. Is there a solution to this problem?
james.still
Full Name: James Still
Company Details: Point 2 Surveyors
Company Position Title: BIM Technical Manager
Re: Deleted Points in Recap Visible in Revit
Post by james.still » Mon Apr 16, 2018 2:08 pm
hi
if you put the points you do not want in a region, you can control this region in Revit via VG and turning them off.
I guess the other option is to export the RCS out again with the points deleted.
I have come across deleting points and then in Revit they are back again!
robertbon
Post by robertbon » Mon Apr 16, 2018 3:40 pm
Hi James, thanks for your reply.
So the 'delete' tool actually means 'hide in Recap' then! And I don't want to export the cleaned rcp as this will unify it and I will lose the mirrorball functionality. Looks like I'll have to do the cleaning in another software then.
wgfletch
Full Name: William Fletcher
Company Details: AEC Industry
Post by wgfletch » Mon Apr 16, 2018 5:52 pm
I would not use the regions tool in recap
It has had HUGE performance impacts for RCP's in recap itself and also when referenced into Revit in my experience
Sometimes doing a save as is required to actually have the points deleted
tsjerkdezwart
Full Name: Tsjerk de Zwart
Company Details: 3DX3
Company Position Title: owner
Country: Nederland
Post by tsjerkdezwart » Mon Apr 16, 2018 6:53 pm
You can get rid of the deleted points by performing a "save as" operation and choose for "remove points".
