Volume Calculations
Discuss all Cyclone 3DR related issues here.
b_clive
Full Name: Clive Bugeja
Company Details: ARC International Surveyors Ltd.
Country: Malta
Volume Calculations
Post by b_clive »
Hi all,
Need some help measuring a volume for an excavated site. I need to extract 2 volumes between 2 planes and 2 meshes. Would appreciate some help with going about the best procedure. I have already created this in 3dr (attached link)
https://drive.google.com/file/d/19shkfQ ... sp=sharing
Attila
Full Name: Tóth Attila
Company Details: Rackarto Kft
Country: Hungary
Skype Name: rackarto
Re: Volume Calculations
Post by Attila »
Now I have to go to a barbecue party. I'll calculate for you tomorrow if it's not too late.
b_clive
Country: Malta
Post by b_clive »
That would be much appreciated :). Enjoy you're BBQ ;)
Also if you would be so kind to record the screen while trying it out and send it over that would be of great help for me to learn the procedure (Or at least a typical procedure)
Attila
Country: Hungary
Post by Attila »
Sorry, I can't download it, it's too big for Google's virus check.
Attila
Country: Hungary
Post by Attila »
1. Separate with object/Separate on both side of the plane, Keep points on side 1 and side 2. Make 3 part.
2. Clean data
3. Create meshes: 0, 0+1 part, 0+1+2 part.
4. Calculate volume with liquid
5. You get the results with a simple subtraction.
Yannick_Cyclone3DR
Full Name: Yannick Stenger
Company Details: HEXAGON
Company Position Title: Product Manager
Has thanked: 17 times
Been thanked: 5 times
Post by Yannick_Cyclone3DR »
Here is a video using Cut&Fill command.
youtu.be/FfaE5dNjB9M
Yannick
b_clive
Country: Malta
Post by b_clive »
Hi Yannick,
That was extremely helpful. Ill give it a go myself but souldn't be an issue now.
b_clive
Country: Malta
Post by b_clive »
Hi Yannick,
So I managed quite easily and i also managed to fix a part of the mesh too since the one i have sent you was not how i wanted it to be for a proper result. While preporming the measurment though i got this warning which i don't really know what that might imply.
Attila
Country: Hungary
Post by Attila »
In the first photo, I saw that the planes were neither vertical nor parallel. This makes it much easier. :)
Yannick_Cyclone3DR
Hi Clive,
You need to get rid of the holes to have good result. Ideally, I would also remove the unchanged parts (not the excavation area) to get the most accurate result.
Yannick
Return to “Leica Cyclone 3DR”
