Rcp ad rcs viewer
Please post all open source software related items here, eg OpenScanTools
cfoster
I have made 70-80 posts
9
Full Name: Chris Foster
Company Details: CEC Inc
Company Position Title: Survey APM and CAD Manager
Rcp ad rcs viewer
Post by cfoster »
I'm looking for something that will allow a property developer with no experience with point clouds to be able to view and navigate around in a project that is in an rcp format. What would be great is a "Recap Light" that only lets them look around. Any suggestions?
cpw006
16
Full Name: Chris Widmer
Company Details: KCI
Has thanked: 3 times
Been thanked: 8 times
Re: Rcp ad rcs viewer
Post by cpw006 »
Not sure which scanner you're using, but could you export a TruView or Webshare? Or Newspin could be an option.
cfoster
9
Post by cfoster »
I used a faro, and the webshare is in the works, but they want to see the actual point cloud, not just the pictures.
cpw006
16
Post by cpw006 »
Newspin may work, you can stream the cloud online, prices are not that bad for 20GB of space and a few users . They could then navigate the cloud, although I have not used Newspin yet, but it looks interesting.
cfoster
9
Post by cfoster »
this project is around 600GB in the rcp format. They have the point cloud, but no way to see it. Uploading it isn't an option. I just need something like autodesk trueview, only for a point cloud.
cpw006
16
Post by cpw006 »
Didn't realize that your data set was that large.
max72
11
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Has thanked: 15 times
Been thanked: 53 times
Post by max72 »
600 Gb is quite large..
A couple of ideas come to mind:
Isn't possible for them to install the recap and use it as a viewer?
As an alternative if they have any autodesk product 2014 or 2015 they should be able to attach it in autocad/revit/inventor or almost anything else.
Can you reasonably decimate the point cloud? In Recap when importing you can set filters and a resample grid. For instance for a building setting the filter to 5-10mm will reduce the file size with no quality loss.
If you export to another format you can then check other options.
Arena 4D: the free versions works as a converter to Arena4D format (including subsampling) and a viewer. Great tool for handling large data with little memory footprint. I think you can run it from a USB drive too, the install is self contained. I have to check on a PC with no former versions of Arena installed. With a license you can create clip boxes, notes and a lot of other options to be viewed with the free viewer.
Potree. You can export to LAZ format. Combining with a reasonable decimation the final dataset will be much much much smaller. The dataset can then (maybe) be uploaded or viewed locally installing WAMP and potree. A more geeky solution maybe..
Oliver Buerkler
15
Full Name: Oliver Buerkler
Company Position Title: Director of Laser Scanning
Skype Name: oliver_buerkler
Has thanked: 38 times
Been thanked: 12 times
Post by Oliver Buerkler »
Hi Chris.
Did you consider delivering your data together with SCENE LT? It´s free of cost and your clients would have the best of both world: panoramic views as well as full 3D point cloud access.
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH
Twitter: FARO_LS_PM
mschuetz
10
Full Name: Markus Schuetz
Company Details: potree.org
Company Position Title: developer
Country: Austria
Been thanked: 5 times
Post by mschuetz »
max72 wrote: Potree. You can export to LAZ format. Combining with a reasonable decimation the final dataset will be much much much smaller. The dataset can then (maybe) be uploaded or viewed locally installing WAMP and potree. A more geeky solution maybe..
To add to that, if you want to give potree a try, take a look at the getting started section. Converting a 600gb dataset will take quite a while but if you use the --generate-page option and convert to your local web server directory, you can watch the result while it's beeing converted. For a dataset of that size I'd try
Code: Select all
./PotreeConverter.exe C:/pointclouds/data -o C:/xampp/htdocs/potree --generate-page -l 10 --output-format LAZ
Input would have to be in tiled las or laz files. rcp is not supported.
cfoster
9
Post by cfoster »
I wish I could've used SCENE LT, but the architects were adamant about us converting everything to rcs and rcp. I've shipped the point cloud to them, and the developer has got it from them. He doesn't have any CAD programs, or anything like that, but basically wants to "play" with the cloud. I'm working on a webshare, but he still wants to see the actual cloud and mess with it.
