Hi there lsf,
We have had a dpi-7 sitting around and are wondering how to register the dpi-7 hand scanner output into our scene 5.4 projects? The dpi-7 has some very odd export settings that I'm not familiar with.
Any help appreciated, thanks.
Handheld scan data into full scan data
- Aaron_Hazen
- Full Name: Aaron J.R. Hazen
- Company Details: Coast 2 Coast Surveys
- Company Position Title: Senior Project Manager - 3d Architecture
- Aaron_Hazen
Re: Handheld scan data into full scan data
Figured out a solution for now using the .ptx export. Registering well.
Old school
Old school
- CWickersham
- I have made 60-70 posts
- Full Name: Caleb Wickersham
- Company Details: EMJ Corporation
- Company Position Title: Virtual Construction Engineer
You should try exporting a .ply or .dp file from the DPI-7 and then use CloudCompare to turn it into an E57.
Hope this helps.
Hope this helps.
Caleb Wickersham
emjcorp.com
emjcorp.com
- 3DForensics
- Honorary Member
- Full Name: Eugene Liscio
- Skype Name: eliscio
- Has thanked: 13 times
- Been thanked: 70 times
I was just doing an exercise today. CloudCompare can open the native file formats for both the DP and Faro formats. I found ply directly into CloudCompare works well for the DP scanner. Just be attentive to your units.
Eugene
Eugene
