Steinbichler Comet L3D 5M for sale
Dot Product DPI-8X, 3D3 HDI, ATOS, Breuckmann & DAVID etc.
3dreveng
I have made 100> posts
12
Full Name: Matthew
Company Details: 3DRE
Company Position Title: owner
Country: canada
Post by 3dreveng »
This portable high end 3D scanning and data capture system has served me very well! The accurate and high quality results have been reliable and repeatable over a significant variety of projects. This combination of high end sensor technology and digital photogrammetry has enabled the successful scanning of small items (microprocessor layouts) up to very large items such as a New York City garbage truck and all of it's "crusher" components. Steinbichler was integrated into the Zeiss product line in late 2105, two companies well known for high end optics and reliability.
The non-contact measurement principle of the COMET LƎD sensor offers the possibility to measure delicate and fragile objects (e.g. of plastic or foam material) that are very difficult to measure using conventional measuring machines/tactile measuring heads. The BLUE LED technology of the COMET LƎD sensor allows capturing of the measurement points in only about 2 seconds. Parts with many features can be captured many times faster using this process than using conventional tactile systems such as Coordinate Measuring Machines (CMM).
Application Areas:
Quality Control / Inspection
Comparison of actual data with nominal data ("as built" compared to "as designed")
Mold and Tool making
Tool reconstruction
Scan data for generation of milling tool paths
Documentation of actual 3D data at tool release
Design
Scanning of design models for further processing of CAD data, documentation
Rapid Manufacturing
Acquisition of 3D data for Rapid Prototyping
Reverse Engineering
3D Scanning
Scanning of art/historical objects, archaeology
INCLUDED (please view photos for item call-outs):
COMET L3D 5M Measurement System (Serial # 5215)
5 Megapixel Sensor with blue LED technology
FOV (6) 100/250/500/800 MM (FOV = Field Of View in millimeters):
Calibration Plates
HP Elitebook
Tripod
Comet Capture software
COMET L3D 5M - Technical data
Resolution 2448 x 2050
Measurement Volume in mm³
100 field-of-view: 120 x 100 x 60 mm
250 field-of-view: 260 x 215 x 140 mm
500 field-of-view: 480 x 400 x 250 mm
800 field of view: 750 x 630 x 500mm
3D Point Distance in μm field-of-view: 45 / 75 / 100 / 250 / 500
18 / 30 / 50 / 100 / 190
Fastest Measurement Time ~2 seconds
Hp Elitebook
Sensor Positioning Tripod or Sensor Stand
Available Software Comet 9.9
SHIPPING WILL BE CALCULATED BASED ON BUYER LOCATION>
WE WILL SHIP WORLD WIDE
contact me @ [email protected] for sample scan data.
Scanner is on Machineseeker and EXAPRO so may be taken down at any time.
Return to “Structured Light Scanners”
