10TB, 12TB, 14TB HELIUM FILLED HDD & INFINIBAND
Post any marterial related the future technology of laser scanning.
jedfrechette
14
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 62 times
Been thanked: 220 times
Re: 10TB, 12TB, 14TB HELIUM FILLED HDD & INFINIBAND
Post by jedfrechette »
smacl wrote: Wed May 08, 2019 5:06 pmWill replacing slower drives with faster drives on the server have the net effect of shifting the bottleneck to the network
I think that's already generally the case, even without SSDs. It's pretty common for a well configured NAS with spinning disks to be able to saturate a 10 GbE connection.
I think it's even possible to build one that will saturate a 40GbE link. If you're chasing that level of performance though the cost off SSDs is probably going to be a drop in the bucket.
Jed
dhirota
14
Full Name: Dennis Hirota
Company Details: Sam O Hirota Inc
Has thanked: 87 times
Been thanked: 379 times
Post by dhirota »
jedfrechette wrote: Wed May 08, 2019 6:25 pm
Shane and Jed
We have all the experimental pieces in place, with our small raid5 SSD server (7TB) with 2 ports 10GbE; 4 port 10GbE raid6 HDD SAS server (70TB) hooked up to a 28 port 10GbE switch; but no time to connect, manage the switch, and test everything out right now since the difference in time for our work flow is 8 seconds improvement. We have improved the workflow loading/viewing time from 146 seconds by network, network cable and workstation improvements. I have not aggregated the 2 ports or 4 ports yet, but plan to when I have more time.
Dennis Hirota, PhD, PE, LPLS
www.samhirota.com
dhirota
14
Post by dhirota »
dhirota wrote: Fri May 04, 2018 7:33 pm A new update on the 14TB helium filled HDD
A year plus later
16TB Seagate HDD available on Amazon for US$470
www.samhirota.com
dhirota
14
Post by dhirota »
BACKBLAZE has published their 2019 Stats
Backblaze Hard Drive Stats for 2019
https://www.backblaze.com/blog/hard-dri ... i=83202592
What is most interesting, and not included in their report, is the testing of the following disks:
Seagate 16TB (ST16000NM001G) disks
Toshiba 16TB (MG08ACA16TA) disks
www.samhirota.com
Return to “Future Technology”
