Apply full 360 dome image to pointcloud
Please show us your 360० Panoramas Movies and Images
b_clive
Forum Supporter
Forum Supporter
11
Full Name: Clive Bugeja
Company Details: ARC International Surveyors Ltd.
Country: Malta
Has thanked: 8 times
Post by b_clive »
Hi everyone,
i would like to know if there is any way possible to apply the full 360 panoramic dome image to a pointcloud for texturing.
im using leica cyclone 7.2 as processing software .
thanks
Clive
Morky
10
Full Name: Paul Moorcroft
Company Details: Derbyshire Constabulary
Country: England
Re: Apply full 360 dome image to pointcloud
Post by Morky »
b_clive wrote:Hi everyone,
thanks
Clive
Clive,
What are you using to capture the 360 pano? There is a way of importing cube face images within Cyclone but we have had not the best results with it.
We use a C10 scanner and an iStar 360 camera with an adapter pole to raise it to the same height as the laser on the C10. Its a case of doing the scan, leave the tripod in place but take the C10 off the tribrac and replace with the iStar and capture the pano. We then use the software for the iStar to export the pano to 'cube faces' then import into the scans in Cyclone.
All sounds very impressive, however the results suffer with paralaxing, whereby the overlayed iStar image appears to overlap and be out of sync with the cloud data when viewed from different angles. :(
That is where we were until the super people at NCTech who manufacture the iStar have come up with their own RGB overlay for solving the problem.
If you go to http://www.nctechimaging.com you will see information and videos on this. I can certainly recommend the iStar as a super piece of kit.
Please feel free to ask further questions. :)
Regards
Paul
"The true sign of intelligence is not knowledge but imagination." - Albert Einstein
jehernandezl
10
Full Name: Jorge Hernandez
Company Details: UNAL Colombia
Country: Colombia
Post by jehernandezl »
Mike Annear
14
Full Name: Mike Annear
Company Details: The Yard Brisbane
Company Position Title: Manager - 3D Design and Scanning
Has thanked: 122 times
Been thanked: 196 times
Post by Mike Annear »
Hi Clive,
It can be done very effectively in Cyclone using a Nodal Ninja camera set up.
I have attached the workflow,
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
jmiranda
I have made 80-90 posts
12
Full Name: Jonathan Miranda
Company Details: IDOT
Company Position Title: Engineering Technician Senior
Post by jmiranda »
Hi everybody!
I have a question regarding the iStar camera. I understand that using the proprietary software you can assign new rgb values to the pointcloud. But, can you have those new rgb values used back in Cyclone and then published using Leica TruView? or will it only be usable on the iStar software using the iStarShare?
Kind Regards,
Jon
Leap3D
10
Full Name: Bas Notenboom
Company Details: Leap3D
Company Position Title: owner
Country: Netherlands
Post by Leap3D »
You will have to export an .e57 file. The e57 and the iSTAR image are processed in NCTech Colourcloud and will produce an HDR point cloud in e57 format.
You can then import the e57 into Cyclone.
Regards
Bas
Return to “360० Panoramas”
