2009-12-02 Version 1.5.2
Features:
Tiepoints in the TPL SOCS can be filtered by point distance now.
Data acquisition V-Line: Automatically color scans after acquisition.
Data acquisition V-Line: Acquire scans out of an image.
Changes:
Function "Remove isolated points" can be used on multiple scans at the same time now.
Animation files (AVI) are split automatically when they exceed 2 GB.
Bugfixes:
Volume calculation: Access violation when saving project after volume calculation fixed.
2D View: Mouse interactions with the view are less sensitive now (Rectangle zoom, Context menu).
3D View: Bugfix when picking single points.
Function "Color from images" did not work when more than one scan was selected.
Reading the inclination sensor values from a VZ-400 scan did not work while the scan is open in a view.
Scaling correction parameters were accidentally locked in the project settings.
2D View: Bug concerning wrong plane position and orientation in viewtype "Falsecolor-Plane" fixed.
Bugfixes concerning VZ-400 image acquisition.
Color information was lost when a PolyData object was created from selected points in a 3D view.
2009-11-03 Version 1.5.1b18 (Beta)
Features:
Selection tool: Select reference coordinate system (Object CS or View CS) for selection. Progress
information.
PTS export: Export V-Line reflectance as amplitude.
Wizard download and convert: Import reflector finescans from a V-Line scanner.
Changes:
Animation paths are stored in an auxiliary file now. This reduces the size of the project file and speeds up
project loading and saving.
"Multiple rename" tool improved (added name prefix and suffix)
RiSCAN PRO revision history
(c) 2009
2
Function "Tile data" improved.
Bugfixes:
Starting two "Color from images" tasks at the same time did not work -> solved.
Problem in "color from images" leading to arbitrary "color rings" solved.
RiScan Pro Version 1.5.2(2009-12-02) release Update
- china007
- I have made 80-90 posts
- Full Name: Hui
- Company Details: Cloudwell
- Company Position Title: Technical Manager
- Country: China
- Skype Name: mychina007
Re: RiScan Pro Version 1.5.2(2009-12-02) release Update
2009-12-16 Version 1.5.2sp1
Bugfixes:
Bug in property "Auto depth" of virtual camera of 3D view solved (caused Orthophoto generation to fail).
Bugfix in defining point on surface.
Bug in panorama view solved (data was invisible).
Bugfix on camera plugin: Canon cameras where not detected properly in some cases.
Bugfixes:
