SCANNING/MODELING SCULPTURES,STATUES,ETC.
Discuss all Archaeology & Heritage related issues here.
Matt Young
Full Name: Matt Young
Company Details: Baker Hicks
Re: SCANNING/MODELING SCULPTURES,STATUES,ETC.
Post by Matt Young » Fri Aug 01, 2014 3:41 pm
I'm actually interested in the original sculpture, is it carved from wood? If it is then I aspire to be that good at wood carving one day.
Jeffc1qps
Full Name: Jeff Cuneo
Company Details: QPS-3D
Company Position Title: Scan-Modeling Division Manager
Post by Jeffc1qps » Fri Aug 01, 2014 3:50 pm
No, Matt. It's actually cast from aluminum. I had a bear of a time removing reflection points. :) Lots of zooming in, rotating, and cutting of stray points....
I have so much to learn. I basically want to be able to scan a sculpture, mesh it into a solid view, and then have it on a free viewer as a deliverable product. I'm getting close....
danielgm
Company Details: CloudCompare
Post by danielgm » Fri Aug 01, 2014 3:53 pm
Have you tried the qPoissonRecon (Poisson Reconstruction) plugin? Otherwise the 2D1/2 Delaunay reconstruction is clearly not meant to be used on such clouds.
And for the Poisson Reconstruction process, you'll need good normals first ;)
Daniel
CloudCompare admin
http://www.cloudcompare.org/
Matt Young
Post by Matt Young » Fri Aug 01, 2014 3:56 pm
Jeffc1qps wrote:No, Matt. It's actually cast from aluminum. I had a bear of a time removing reflection points. :) Lots of zooming in, rotating, and cutting of stray points....
Ok, thought it might be - I am always trawling the net for ideas to carve things and see a lot of amazing sculptures like that. I know carving seems a little old fashioned when we have 3d printers these days... I just like to be old fashioned ;)
I hope you continue to achieve some good results with what your doing.
Jeffc1qps
Post by Jeffc1qps » Fri Aug 01, 2014 9:02 pm
daniel, I have tried the Poisson setting, but it just draped the whole area around the eagle with a mesh. the mesh on the eagle parts looked good, but the added curtain around it was bad. I did the set normals setting on Cloud Compare, but again, i'm not trained for this as of yet and i'm just clicking to see what happens. :) lol
danielgm
Post by danielgm » Fri Aug 01, 2014 9:48 pm
It's definitely an algorithm that is a bit hard to tame. You'll need very clean normals, and you'll also need a closed shape (i.e. points all over the surface, not on one side only).
Anyway this algorithm and much more others are also available in Meshlab for instance (which is better suited for the job, as its name indicates ... contrarily to "Cloud"Compare ;).
Daniel
CloudCompare admin
Jeffc1qps
Post by Jeffc1qps » Fri Aug 01, 2014 9:56 pm
Yeah, i realize i'm using it a bit out of it's context. Thanks for the help!
Jeffc1qps
Post by Jeffc1qps » Mon Aug 04, 2014 3:34 pm
So, i've loaded and attempted MESHLAB. I'm getting an error that says 'Opening Failure'. Support is just forum search it seems like. Anyone want to point me in a direction I can find information? Thanks.
Return to “Archaeology & Heritage”
