Monitoring Structural Movement?
- scanmannss
- Forum Supporter
- Full Name: Mike Blair
- Company Details: Stem Engineering Group
- Company Position Title: Survey and Design
Re: Monitoring Structural Movement?
In the mining industry we often reference the same area for monitoring production and volumes. The first photo shows the original rock in greyscale and the shotcrete added thereafter. The second photo shows a scan before and after a blast has occured. The key is to have a safe control network to resection into and colour code each result. The last photo is where we monitor wear on the refractory lining inside a laddle. I simply set up a reference plane from the outer surface and re-scan the inside for volume calculations. Same senario.
MIKE BLAIR
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
3D Reshaper can also compare two seperate mesh's created from laser scans in much the same way.
I have used it in the past to map bulges in large fuel storage tanks as a direct comparison to design.
- pburrows145
- Full Name: Paul Burrows
- Has thanked: 109 times
- Been thanked: 123 times
Ben, if you have Cyclone Survey you are mostly there (without having to spend additional cash). Mesh to mesh deviation, Mesh to Points deviation, Volumes etc. It wont necessarily give you the same kind of reports as Qualify and Reshaper etc (though you can colour code in any direction with a few simple tweaks of the coordinate system and the UP direction), but it is a good starting point.
Otherwise the cheaper option between Geomagic, Polyworks and Reshaper is the latter (and that's not just because we sell it - it genuinely is). I would just get a demo of each one and decide which is best for you. Personally I do not get on with Polyworks...
- Full Name: Alison Bentley
- Company Details: WSP
- Company Position Title: Land Surveyor
It is also possible to get the results you are after using Trimble Realworks (Although not for the larger datasets!).
My attempts at this type of work have produced the best outputs using 3D reshaper mesh to mesh function and are also achievable in Realworks using a baseline dataset or from a plane and assessing the difference in normals from the plane, as its important with repeat work that you are assessing from the same angle.
I also found that assessing one face of a building at a time produced much "nicer" results.
Of course if you were doing a non planar object you could create a cylindrical plane. It's then very easy to replicate when you return to site!
Good Luck!
Ali
Good Luck!
Ali
- Phill
- Full Name: Phillip Nixon
- Company Details: SKM
- Has thanked: 7 times
- Been thanked: 45 times
Ben
If you dont want to do it with one of those fancy schamcy packages, you can do it with Cyclone and Arcgis. Make an alignment lined up with the wall you are monitioring, and change the z axis so it comes out of the wall by moving the up direction to say the x axis. Then colour the cloud using elevation and greyscale with lots of colourchange (256) and a 1 or 2mm delta. Then export an image. Then do the same with the other cloud. In Arcgis do a comparision of the two images (dont ask me how to do this bit, I got someone else to do it). The change in colour values is movement of the wall.
Phill
Phill
