Long Range Scanners
dgichicago
15
Full Name: Aaron Jones
Company Details: Dynasty Group Inc.
Company Position Title: Engineer - Laser Scanning
Skype Name: jonesat
Long Range Scanners
Post by dgichicago »
I am trying to gather some information on what long range scanners are available on the market. I am looking for tripod scanners that have a +1000m range. So far this is what I've found, and I've included is their max range:
Riegl LMS-Z620 - range 2000m
Riegl LMS-Z420i - range 1000m
Riegl LPM-321 - range 6000m
I-Site 8800 - range 2000m
Optech ILRIS-3D - range +1000m
Honorary Member
Honorary Member
16
Has thanked: 45 times
Been thanked: 40 times
Re: Long Range Scanners
Post by Matt Young »
There is also the HDS 4400.
http://www.maptek.com/forge/march_2009/ ... nners.html
Thumbnail Screenshots by Thumbshots
Basically the I-Sight scanner.
jedfrechette
14
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 62 times
Been thanked: 220 times
Post by jedfrechette »
dgichicago wrote: Optech ILRIS-3D - range +1000m
The ER option for the ILRIS pushes the range out past 1500m for an 80% reflective target.
igneous101
14
Full Name: Jason Richards
Company Details: Maptek Pty Ltd
Company Position Title: Sales and Technical Services Manager
Post by igneous101 »
It may also be worth taking into consideration the workflow & ease of use to acquire your data. You say your after a long range scanner, but what is the exact application? Can we ask? Do you need survey control, what type of deliverable are you after so therefore is software a consideration in the overall system?
joe.3dlm
16
Full Name: Joe Beeching
Company Details: GeoSLAM Ltd
Company Position Title: Customer Success Manager
Post by joe.3dlm »
You should also consider the reflectivity of the target material.
The maximum range is affected by, among other things, the reflectivity of the material being scanned. Not all manufacturers use the same criteria when describing the maximum range (e.g. Riegl quote to a target with 80% reflectivity, Leica 90%, Optech 90%, I-Site 80+%) so if the range is critical, don't just assume that the quoted maximum range will be achieved.
As a general rule, I usually work to 80% of the quoted maximum range as achievable in typical use.
Other factors are:
- moisture content of target
- atmospheric conditions (visibility, humidity)
- ambient light (bright sunlight have have a negative impact on the range performance)
- eye safety (longer range scanners sometimes have less eye-safe lasers)
Joe
dgichicago
15
Skype Name: jonesat
Hey guys,
Thanks for the replies. I wanted to answer some of the questions that are floating around so far...as for the type of project I can only say that it is not very close to where we are setup. Survey control will be used, a combination of GPS and traditional methods. The deliverable is still be determined, but will be a mesh/TIN or contour lines. As for the % reflectivity of the the objects being scanned, that has been taken into consideration and the reason we are looking at +1000m range scanners. Other than perhaps the moisture content of the target (thanks Joe) most of the parameters have been accounted for in our assessment of what scanner to use.
If there are any other long range scanners out there not mentioned, post away.
Aaron
jedfrechette
14
joe.3dlm wrote:The maximum range is affected by, among other things, the reflectivity of the material being scanned. Not all manufacturers use the same criteria when describing the maximum range
Good point, although at least Optech and Riegl provide nice plots of range vs. reflectivity.
joe.3dlm wrote:Other factors are:
I would also add:
- target orientation (high incidence angle -> low backscatter intensity)
Return to “Tunnel & Mining”
